Quality condensor fan motor
Hello all,
Im looking for a well built long lasting condensor fan motor. I've replaced it about 6 year ago and the plastic bushing inside has worn down and allowed the rotor to rub against the case to the point where it stopped rotating. The original seemed to last a lot longer.
Thanks In advance
This is what I put in my unit back in 2017 so I could run a fan controller. It sure seems to take the abuse of running slow. It's ball bearing and I believe there's plenty of power, rpm etc variations available.
It's a 70C rated ball bearing AO Smith / Century motor.
https://www.amazon.com/dp/B007ATNJGQ?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_44
OEM
If you have a lot of start stops, that’s probably what’s killing that motor0
