Makeup air inlet
This may be a stupid question but what do I use outside for an air inlet on a 6" pipe that's feeding make up air to an enclosure I'm exhausting 400 CFM from?
I know what to use as an exhaust damper but I've never seen anything as an inlet damper / screen.
Rain isn't a huge concern.
I have seen them mostly in sheetmetal fitting catalogs. I don't think a damper would be code unless it is motorized and interlocked to the appliance. Also look around where you see fan in a can products.
I don't think there's any code that covers what I'm doing. 😉
Oh, it isn't to meet the code that requires exhaust fans over i think it it 400 cfm have a makup air supply?
No idea,
Is that residential? Commercial? We do not have any atmospheric burners.
This fan is rated 389cfm.
Interesting.
No, the inlet is to stop the fan from pulling conditioned air out of the building.
It's a long long story.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
yep
But I have concerns about temperature variations from outside effecting tolerances.
So, we'll see.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
vs the ones from friction?
The problem is making the fan pull air from where you want it to come and not where the air wants to come from.
Would an ERV make sense?
They also offer a (FAV) Fresh Air Ventilation System that gets ducted to the HVAC return.
There are a bunch of options for vents and dampers here:
You can get one with a screen and a flap then put a screw in the flap to hold it open.
- 15.8K Strictly Steam
