Maytag Refrigerator Ice Maker Frozen
I have a Maytag French Door refrigerator, MFX2571XRM1, purchased around 2011. The icemaker, W10300024, and ice bin became full of ice. Upon removal of the ice bin, it was found that the movable arm for crushing ice cubes had become disconnected from one of the pivots and was jammed. It is not known how or when it happened. The arm is the plastic piece with the metal rod end in the picture.
With the ice bin removed, I removed all ice cubes and other frozen water from the bin, including breaking up cubes in the tray and in other places in the bin housing.
Then I removed the icemaker, again removing ice cubes and surrounding frozen water from the mold. For those not familiar with these icemakers, there is a heater built into the ice cube mold that operates for several seconds after the cubes are formed to slightly thaw where the cubes contact the mold. This makes it possible for the fingers to rotate the cubes out of the mold and into the tray of the bin.
I looked at a few You Tube videos and took some multimeter readings. Since the icemaker was disconnected from the power cable, I could not check voltage presence. I was, however, able to measure the resistance of the heater/icemaker assembly. The blue label says the icemaker is 260 watts and 115 volts. This calculates a resistance of 50.9 ohms. There was a comment in one of the videos about the resistance being 72 ohms, which comes out to about 184 watts. Looking back at that video, the label for that icemaker said 185 watts. I conclude the heater/icemaker has sufficient continuity.
At this point I am unable to conclude exactly what happened. Since I have no evidence the water supply valve is leaking, I tend to think the excess may be because of the high humidity this spring and frequent use of the ice maker. Maybe some cubes got “stuck” and forced the flap over the opening, where the cubes/crushed ice come out of the bin and through the passage in the door into the container for the ice, to be out of position. I can’t positively prove if the arm being out of position, kept the flap from closing, thereby constantly allowing humid air from the kitchen to entering the ice bin/icemaker. Or if opening the refrigerator door in the humid weather allowed moisture into the refrigerator which then condensed in the mold. All guesswork.
While my preference is to know what happened and not get into putting the unit back together, only to have to remove it again, I tend to think, quit guessing, put it back together and see what happens.
I am trying to figure out the best next steps. A new Maytag icemaker is almost $300 at multiple sources. There are lots of aftermarket “equivalents”, but I do not know which are reliable and if the icemaker is not the cause, what is??? Being a DIY guy with my apartment heating system, I try to fix things on my own, many times with advice from HHers. Maybe someone has experience with these icemakers.
whirlpool doesn't make that icemaker. if you buy one from supco or someone like that it is the exact same part.
mine did something like that a decade ago. i thawed it out and it hasn't done it since. don't know what happened. it is also possible the timer motor is failing and got stuck on the water valve opening.
note that there are little holes in the front to stick meter probes in to to see what is happening with it in place
Thanks. I found them on eBay, too,
I used the holes to verify the resistance reading.
Did the arm get moved out of position? I'm not sure what is the chicken or the egg.
Bag of ice at the corner store LOL.
I have a fridge with an icemaker but it is not hooked up. I know if it is not hooked up and the ice maker arm is not in the off position it can drive the fridge a little crazy. I have seen this before on other fridge.
That's the problem with new equipment. You get a circuit board with a bunch of wires and the MFG doesn't give you a sequence of operation so your left trying to figure out what is going on
This morning I informed my wife I want to try to "fix" it once. She then commented about no icemaker. I immediately reminded her the refrigerator has a freezer compartment, the refrigerator in the garage has a freezer compartment and the brand spanking new upright freezer in the garage is a freezer.
I didn't mention that a convenience store is within walking distance….needed to prevent having my head chopped off.
She looked in the basement for ice cube trays and didn't find any.
By the way for all the parents and grandparents, one of my granddaughters has one of those rubbery fidgit thingys. They are great for mini slushies, barely big enough to fill a tooth cavity!
i'm pretty sure whirlpool acquired that design from seeger when they bought them in like 1960. i'm not sur if there is a pcb in there or if it is just metal strips in the plastic but there is no microprocessor control of the ice maker, it is just a timer run by the motor that flips the cubes out of the ice mold. it may have a contact or a thermostat that asks the refrigerator to run to freeze the ice. I suppose that would get weird if the duct that directs cold air on the ice mold is out of position.
I don't see any duct for cold air to circulate around the mold. The arm I show in the picture is at the bottom of the bin assembly. It looks like it rotates to close off an opening for cubes and directs the cubes to the crusher.
I don't fully comprehend how the thermostat, fill valve, fill arm and ejection motor interact. Obviously, the fill arm has to sense the need for more ice, then the fill valve actuates for a specific period of time (not volume), when the ice is frozen, the heater comes on to loosen the cubes and the motor turns the "fingers" to remove the cubes from the mold and let them fall into the ice tray (referred to on the web as ice bucket).
You should be able to find the service/installation instructions for that ice maker somewhere.
The arm at the bottom of the ice bucket doesn't have anything to do with the icemaker, it is part of the dispenser in the door.
The arm at the top right of the icemaker is what controls if it ejects cubes or not. If it is down far enough when the cubes freeze it starts another cycle. If the ice or the stop is holding it up, it doesn't cycle.
The duct may just be a cutout in the back partition or the way the vents are oriented in the back of the freezer compartment. My side by side has a little duct that snaps in to the back partition that directs cold air on the ice mold.
I found this web page. It appears to be the same design as mine, but mine has a 260 watt heater on the label and the motor resistance is around 6500 ohms by the multimeter..
I haven't found a Maytag specific sheet. But what I have found is probably equivalent, except for the ratings of the motor and heater.
That top part of that page is the tech sheet for that ice maker. I doubt that the fridge is maytag specific, whirlpool probably sells it as several different brands with minor cosmetic differences.
I reinstalled the icemaker and bin. The fill valve operated for the expected amount of time. Now it's just wait and see what happens.
i probably would have just left
First cubes at 12:45, note the gap between them on the right and no gap on the left. If you look from the top of the cubes the ice is higher on that side.
The icemaker refilled and dropped another load at 3:08. After it did, I pulled out the bin to see the cubes and when I removed the bin, water dripped from the icemaker. See the pic above.
Conclusion seems to be there is too much fill water going to the mold. I will check a few more loads, to see if it settles out to the right amount or if I have to adjust the fill amount.
He's probably right.
They're garbage.
And gone where? Every place has the same junk.
yeah, it shouldn't be connected like that. make sure it is level too. put the arm up and put a little cup or something under the fill tube, make sure the fill valve is holding
I'll see how much excess water/ice comes out in the next load. In the mean time I will find a replacement valve, but I am going to change the water filter. I have one on hand. It's a bit embarrassing, but it was installed 7/10/2021!!!! Supposed to be changed every 200 gallons.
Self inflicted wound…maybe the valve weeps, then stops and changing the filter might make a difference…I think I am kidding myself, but it needs to be done anyhow.
More to follow.
4 years for a water valve isn't very long. that is something where you can buy the same part off the same line for $100 with a whirlpool logo or elsewhere for $8
4 years for the water filter. I should have been more clear. The valve is original.
And you wonder why this guy is unemployed.
…the one time there is a service call on a Maytag, and no one suggested "Call the Maytag Man"
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 986 Plumbing
- 389 Solar
