Oil to Gas conversion steps
Avocadomilk
Avocadomilk Member Posts: 1
hi all,
Can someone outline what are the steps for an oil to gas conversion specifically when you get to the inspection part. Can someone please outline what happens after the DOB inspection?
also on a side note do the dob guys try to look in other parts of the house and find any faults? We have heard stories where they came for one thing e.g gas inspection and then ended up giving violation for a kitchen not being up to code.
    pecmsg Member Posts: 7,055
    seeing how it came out of the factory for oil I don’t think the manufacturer would approve gas on the same unit.
    that might be an issue.
    Jamie Hall Member Posts: 27,359
    Presumably you are having a pro. do the conversion, and they have determined that the boiler can, in fact, be converted and that the chimney is suitable for gas? If so, let the pro. handle it all…
    Generally a building inspector won't look at things which weren't touched or affected — but they can if so minded, so it pays to be nice to them.
    SuperTech
    mattmia2 Member Posts: 16,746
    This sounds like it might be a nyc specific question and things can be different there.
    pecmsgold_diy_guy
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,587
    Not clear from the question, if the actual boiler is being converted or not.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,546
    Right, it very well may be complete boiler replacement rather than just the fuel gun. In NYC especially, prepare to pay a considerable sum in D.O.B. permit, fees, and filing. Your NYC licensed master plumber will be familiar with the procedure. I strongly suggest referencing the Find a Contractor section on this site.
    It really depends on the inspector that shows up and what his pet peeves are. Be prepared for the inspector to need access to all areas of the basement. If you look at it as wanting to "do things right," by your home or building, you'll have peace of mind in the years ahead.
    I see real estate closings held up all the time by lack of proper permits, outstanding violations, and no C of O.
    Mad Dog
    STEAM DOCTORLong Beach Ed
