R-32 vs R-454B
Greetings,
I need to replace my R-22 split system in the next year due to a leak and am curious if I should be looking at R32 or R454B equipment. Are techs seeing one having less issues than the other?
I was one vacation at an AirBNB a couple weeks ago and the first floor AC stopped working. The system was only 2 weeks old and the refrig. gas sensor in the air handler failed. Makes me a bit nervous about the new technology.
Thanks.
where is the leak? i'd fix it if it is fixable.
Doesn't matter. One is a blend. One isn't. The manufactures have picked theirs, mostly because they've been using it globally for years.
Did the sensor reset and start the system again?
The only thing I've noticed so far is it seems like a lot of guys are having problems buying R454B. I'm sure that will change in the very near future, but right now I'd go with R32 unless I knew I had some 454 on hand.
If the system comes with enough of a chart for the job it's likely a moot point unless something goes wrong.
did the sensor fail or did it detect refrigerant? If the sensor actually failed its a roughly 10 minute fix, if it detected refrigerant near the coil then it's finding a leak for you, letting you know the coil might be bad and the manufacturer gets to warranty it rather than paying a tech to chase down leaks. It doesn't matter what kind of refrigerant is in the system those sensors are pretty much the same either way, probably made by just a small handful of companies worldwide, they also don't just detect R-32 or R454B you could take a can of duster and spray it at the sensor and it will trigger
The bad sensor in the AHU has nothing to do with the refrigerant
There talking about a refrigerant detection sensor.
I would use the R32 over a blend if I could .. Fracture would be out of the equation …
The refrigerant detection sensor has nothing to do with which refrigerant you choose though, it's the same sensor essentially just calibrated to go off at a different level depending on which refrigerant, you can blow a can of duster at either to trip them
Edited my post to say R-32 instead of R-35. Typo on my part.
Fire safety regulations have gone waco decades ago.
I agree that the detection sensor has little to do with choosing between R-32 or R454B, but is there because of the flammability of those refrigerants. You wouldn't have the detection sensor in a system with non-flammable refrigerant.
That is why I think the failure of the detection sensor has the OP nervous about the new tech.
