Chimney Liner
bdp1999
bdp1999 Member Posts: 60
What's the average price to have a two story Chimney Liner installed? What's the best way to measure the length the Liner needs to be for the install? Is it something that a DIYer can do? Plumbing, tile, and electrical experience.
    Jamie Hall Member Posts: 27,006
    We don't do price on full jobs here — way too much variation to be fair — or useful.
    The best way to measure the length is… tape measure from top to bottom… no magic in that. I might add that a partial liner is worse than no liner at all.
    Can a DIY person do it? A resounding maybe… it would depend on the skill and ability and knowledge of the person — and the complexity and difficulty of the job.
  • bdp1999
    Which Liner would that be? As for the measurement, it's a little difficult because it goes down, then over into a basement. So I'm not sure on how many extra feet I need to add. Do you recommend any brands or sites?
    The liner is in the chimney. Do you mean the chimney jogs or turns? If so, it is NOT a DIY job. Even properly connecting a breaching to a chimney liner isn'tareally goodcandidate…
    EBEBRATT-Ed Member Posts: 19,891
    Go on the roof with a rope tie a wrench or something to the rope for a weight. Lower it down. When you get the right length tie a knot in the rope pull it up and measure it.
    Use a stainless steel liner.
    If it is a straight shot its not to hard. If it isn't call a chimney sweep
  • bdp1999
    Not a straight shot, I'll have to open the wall up in my basement. Just didn't want to leave it open for a long period of time.
    HVACNUT Member Posts: 7,307
    edited April 2025
    Do you own a draft gauge for when you're done? You don't do electrical work without a meter, right? If you replace a motor, do you check amps, or just flip the switch and leave?
  • HydronicMike
    HydronicMike Member Posts: 293
    1. Why do you think you need a chimney liner?
    2. If you need a chimney liner, then you should get a Level II to check the integrity of your chimney.
    A liner doesn’t fix structural defects. After the liner is properly sized & installed you would need a full combustion test to make sure it’s safe to operate your appliance(s).
    So it’s not a DIY project.
