Chimney Liner
What's the average price to have a two story Chimney Liner installed? What's the best way to measure the length the Liner needs to be for the install? Is it something that a DIYer can do? Plumbing, tile, and electrical experience.
We don't do price on full jobs here — way too much variation to be fair — or useful.
The best way to measure the length is… tape measure from top to bottom… no magic in that. I might add that a partial liner is worse than no liner at all.
Can a DIY person do it? A resounding maybe… it would depend on the skill and ability and knowledge of the person — and the complexity and difficulty of the job.
Which Liner would that be? As for the measurement, it's a little difficult because it goes down, then over into a basement. So I'm not sure on how many extra feet I need to add. Do you recommend any brands or sites?
The liner is in the chimney. Do you mean the chimney jogs or turns? If so, it is NOT a DIY job. Even properly connecting a breaching to a chimney liner isn'tareally goodcandidate…
Not a straight shot, I'll have to open the wall up in my basement. Just didn't want to leave it open for a long period of time.
Do you own a draft gauge for when you're done? You don't do electrical work without a meter, right? If you replace a motor, do you check amps, or just flip the switch and leave?
- Why do you think you need a chimney liner?
- If you need a chimney liner, then you should get a Level II to check the integrity of your chimney.
A liner doesn’t fix structural defects. After the liner is properly sized & installed you would need a full combustion test to make sure it’s safe to operate your appliance(s).
So it’s not a DIY project.
- 117 Geothermal
