System2000 water tank leaking
skyline137
skyline137 Member Posts: 9
My system 2000 water tank needs to be replaced. It seems like a proprietary tank for system 2000 only. How do I find someone who works on these systems? The tank is about 31.25 high and 22.5 diameter.
    EBEBRATT-Ed Member Posts: 20,165
    I am sure Energy Kinetics will respond. You probably need an EK dealer in your area. Who services your equipment now?
    SuperTech
  • Big Ed_4
    Big Ed_4 Member Posts: 3,530
    Walk into a local supply house that sells System 2K and ask the guys at the counter …
    HVACNUTSuperTech
  • HydronicMike
    HydronicMike Member Posts: 343
    I don’t think supply houses sell them. Sold directly from factory to contractor.
  • kcopp
    kcopp Member Posts: 4,675
    There is nothing special about the std storage tank… You can very easily modify an electric WH to fit.
    I have done it a number of times.
    sdodderGrallerthot_rod
    HVACNUT Member Posts: 7,436
    Not everyone knows how to modify a standard electric water heater so the boiler can purge properly.
  • jringel
    jringel Member Posts: 52
    It is always best to replace it with a tank from Energy kinetics but if you are looking to use a standard electric tank there are instructions on our website to convert a standard tank for use with our boiler. Feel free to have your service provider reach out to tech support for assistance if needed at 800-323-2066
    John Ringel Energy Kinetics
    RogerkcoppHVACNUTGreening
