Water Heater Burner Flame
Does this look normal for the flame of a gas water heater?
as much as anyone can tell without test equipment. the orange is from sodium either in the air or on the surfaces
Hi, It's not normal. I think I'd start with removing and cleaning the burner. See what improvement that gives. I suspect "gunk" has built up on the burner and is impeding gas/air flow.
Yours, Larry0 -
Flame looks long and lazy to me. I would also check the flue pipe and chimney.
You should have the water heaters gas pressure tested and serviced.
Is this a water heater that was purchased at a big box store? If so thats ok, but one brand (I don't remember which one) had a run of bad gas valves. Get it looked at. Its probably covered in warranty.
It looks lazy but it's also a picture. Try and post a video
It’s a Rheem from HD. I’m unable to post a .mov video file.
I think thats the one. Get in touch with HD. It will most likely be a warranty covered new burner and gas valve replacement.
- 15.8K Strictly Steam
