Pump insulation
Wellness
Wellness Member Posts: 154
edited March 25 in Plumbing
I noticed that the new Grundfos ALPHA 15-58F Smart ECM High Efficiency pumps don't have the same insulating jackets like the discontinued ALPHA2 15-55F Cast Iron Circulators. I'm sure this is a cost saving move. But I'm wondering if you pros out there think there was any energy saving benefit with the insulating jackets in the first place (assuming the pipes in the rest of the system are also insulated) or even whether it caused overheating of old pump.
  • Intplm.
    Intplm. Member Posts: 2,633
    A lot of times the insulation was tossed aside either when first installed or at a later date.
    GGross
    pecmsg Member Posts: 6,052
    In chilled water systems it's to prevent condensation and hazards. HW systems I see no return on investment.
    Alan (California Radiant) ForbesIntplm.PC7060
    EdTheHeaterMan Member Posts: 10,433
    Allways looking for a fast buck! LOL
    I can’t let you have it all
    PC7060EdTheHeaterMan
    hot_rod Member Posts: 25,055
    The clamshell type that enclose everything but the powerhead are what you want for chilled water.
    If all the piping on a hot water system were insulated, it would be nice to valve the pump bodies insulated also.
    Whenever I get a Euro pump, it comes with a complete insulation, maybe it is an energy standard requirement in some other markets?
  • plumbj
    plumbj Member Posts: 2
    Yeah, the jackets helped a bit with heat loss, but if your pipes are already insulated, the difference was pretty small. Overheating wasn’t really an issue since the pumps were built to handle it. Looks like they just ditched them to cut costs and simplify the design.
    mattmia2 Member Posts: 12,694
    I thought you could order with or without.
  • jumper
    jumper Member Posts: 2,447
    Agree about HHW. With CW what about condensation under insulation? Belt plus suspenders folk paint (borosilicate); wrap; insulate; wrap again. Or install fan.
    you need a vapor barrier on the outside. Fiberglass gets sealed with mastic
  • Wellness
    Thanks for the feedback.
    if it’s hot water or steam you don’t have to worry about a vapor barrier
  • jumper
    Exactly. Emphasize outside.
