New Home Laars Combi Boiler
eengelhart
eengelhart Member Posts: 6
Hi Everyone,
I’ve recently finished our new home build and have been experiencing issues with water pressure. I’m wondering if there’s more for me to do before calling in outside help.
Boiler: LAARS Combi Boiler 140
Propane
Heat set to 125*F
Issues: Low water pressure when showering. Water seems hot enough, just feels like more of a heavy rainfall than a shower.
I’ve adjusted the mixing valve already but I’m wondering if there’s more balancing to be done. Cold water pressure is fine, and sinks have decent hot water pressure.
It is a 3/4” supply to 1/2” branches. Upstairs shower is the one in question. Also, upstairs sink hot water takes very long to get hot.
Any help is greatly appreciated!
-Evan
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,537
    The intake screen could be clogged on the unit. Check that next. Mad Dog
    Ironman
  • Ironman
    Ironman Member Posts: 7,908
    The screen on the water inlet may be clogged or the internal plate heat exchanger may be fouled from hard water.
    I can’t tell for certain from your pictures, but it doesn’t appear that there are any valves provided for de-scaling the heat exchanger.
    Bob Boan
    Mad Dog_2
    hot_rod Member Posts: 27,394
    If it is brand new, I doubt you have scaling issues. Yet!
    I don't know if that model mix valve has screens on H &C the union versions do. Check the installation manual. That is another common "choke" point, at the mix valve.
  • kcopp
    kcopp Member Posts: 4,673
    On another note why didnt they run a combustion air intake? That would be best practice especially where the boiler is located in the laundry room…
    Mad Dog_2
  • Mad Dog_2
    Kcopp..
    C'mon..thats extra...ha ha... Mad Dog
    kcopp
  • psb75
    psb75 Member Posts: 1,126
    Check any screens that may be in the anti-scald/mixing valve.
