oversized water heater
Hi, My mother has a 1 family house. A few years back my father installed a 200 or 250 gallon AO smith gas water heater. The plan was to convert the house to a 2 family. Currently there are only 3 people living in the house and the gas bill is through the roof. I lowered the temperature on the water heater but it's not that hot now. I am not sure how to make this water heater efficient it's definitely oversized for the house. The only thing I can think of is to put in a tankless water heater.
Any suggestions would be great.
Thanks!
    EdTheHeaterMan Member Posts: 12,151
    edited March 2025
    A 40 gallon water heater is sufficient for 3 people. How old is the large commercial heater?
    Can you sell the AO Smith Commercial on the internet? They are not cheep so you can get a couple of hundred for a used one if it is not too old. Remember you paid retail for the tank and the installers, You are not gong to get anywhere neat what you paid for it. You will be selling at less than wholesale cost and the buyer needs to pick it up. Not like getting a new one delivered by the supply house.
    ethicalpaul Member Posts: 8,781
    edited March 2025
    Why haven't you thought of taking the monster tank offline and installing a 40 or 50 gallon gas or heat pump water heater? Not judging, just wondering if there's some reason
    Looking at how much a 250 gallon AO Smith water heater costs, you could probably sell it and pay for many years of hot water.
  • Intplm.
    Intplm. Member Posts: 3,013
    Suggestion…Replace the water heater with a properly sized water heater that will accommodate the needs of the occupants.
    Alan (California Radiant) ForbesethicalpaulHot_water_fanPC7060
  • jesmed1
    jesmed1 Member Posts: 1,474
    edited March 2025
    Just for reference, we have a 75 gallon gas water heater in a 4-unit condo building with 4 bathrooms and 6-8 occupants, and we've never run out of hot water.
    As others have pointed out, 200 gallons for a 2-family is massive overkill.
  • Grallert
    Grallert Member Posts: 1,117
    Simply drain it and take it of line or add it in series before a properly sized water heater. We have a BTHL-250 servicing 25 teenaged girls and two families including a full four washer laundry room. That's a pretty big water heater lol.
    hot_rod Member Posts: 27,446
    250 if a very large tank, depending on the burner size it may be an ASME tank, worth some $$$ depending on the age
    How is it vented.
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,093
    edited March 2025
    Hi, A forty gallon gas or fifty gallon HP would cover the need unless there is a ten gpm showerhead 🙀 A question is what else is using gas? Has the system been checked for leaks?
    Yours, Larry
    ps, I've also had water leaks keep a gas heater firing up. So have a look at your water meter when no water is being used.
    GGrossGrallert
    pecmsg Member Posts: 7,053
    water heaters need to run at 140* to kill the legionella bacteria. Then a mixing valve to limit the water temp to 110-120* max.
    just get a smaller heater.
    mattmia2 Member Posts: 16,745
    i would be less concerned in a reasonably sized water heater but with all that water that is going to sit for days or longer it needs to be hot enough to sanitize the water.
    my WH was set at factory at 120F and it warns me of scald danger if I even bump it to 130F so I think the lawyers at Rheem at least think 140 isn’t necessary
    it is a tough call, legionella, or scald litigation.
    Elevating the tank temperature and mixing down is one option, or a chemical romance.
    It comes down to your risk aversion, in some places cold water lines can harbor legionella. Piping run through attics in hot locations, for example. Now what?
    That is one argument for a chemical solution.
  • Larry Weingarten
    Hi, To complicate things, the age and condition of the occupants and potential visitors needs to be factored in. For a nursing home, absolutely heat to 140F and mix it down. For healthy adults, I like 130F as something they can deal with. I always ask about and try to get people to pay attention to the water temperature and things like fluctuating temps in the shower. Part of our job is to educate.
    Yours, Larry
    In a 40 or 50 gallon tank where the municipal water with residual disinfectant gets replaced daily is much less of a concern than a 200 gallon tank where maybe 1/4 of it gets replaced daily so the disinfectant concentration will be much less as it sits and degrades. Of course if the occupants don't bathe daily or are out of town a lot then the same concerns exist with the smaller tanks.
    Tell Rheem, not me 😅
    But seriously, that document skips over the 122 range where it does kill it, it just takes longer.
    I will also say that every year about 8,000 - 18,000 people in the US are hospitalized from Legionnaires from household plumbing (these are estimates because it's difficult to say exactly the source).
    33,000 people in the US are hospitalized due to bathroom slip and fall accidents every year so I hope we can all chill a little bit with the heavy legionnaires concern in the home.
    Hot_water_fan
    Legionella protection makes sense in cases of hospitals, retirement homes, places where people are ill opr have compromised immune systems.
    Every home in America??? I suppose it like buying insurance, what type of policy, how much coverage, etc, etc.
    The mixing valve is a simple inexpensive solution, and it extends your WH output.
    I think tank life is shortened with higher operating condition, more mineral precipitation.
    Pros and cons
    ethicalpaulLarry WeingartenPC7060
    The reaction that corrodes the tank happens faster at higher temps too.
    There are pretty definitive ways to kill legionella. There are thousands or more sources of falling.
  • Hot_water_fan
    Hot_water_fan Member Posts: 2,241
    edited March 2025
    you could replace it with a smaller tank. That said, it’s winter. The high gas bills are probably unrelated to the water heater. What was the gas bill in August? I suspect replacing the heater would be a net cost and a bad use of their time and money.
    Larry Weingarten
    Of course if it is a condensing A O Smith Cyclone, it could be pretty efficient :) And worth more than my truck!
