Packing Heat
124»
  • BTUser
    BTUser Member Posts: 41
    Thank you for this, I will be doing those tutorials and running our numbers through when time permits.
    38 cents and 8416 sound reasonable. I gathered the numbers on my existing 6.48kw:
    9760 Average annual production over 5 years of monitoring data. It was knocked out of production for around one month summer, so SunPower's predicted production from the original paperwork (10,122) is quite close. Assuming their prediction is spot on, I calc I'd need to add 5.39kw to go the A2AHP route. That'd be 15 more panels if I somehow found the exact same type. And, 15 more panels happen to be exactly the amount that could fit on the remaining prime territory remaining on the roof. Panels are 3.5x5 so that's about 262.50sqft of additional paneling. When I bought the first ones in 2018, the panels ran $1000 each installed which makes for some easy math.
    There is a problem, though. My understanding is that adding additional PV panels would knock us out of the NEM 2.0 we're grandfathered into until 2038. California's NEM 3.0 appears to be significantly worse for people like us who have optimized our energy consumption patterns around avoiding Peak pricing. I think it would worsen the math not just for the 15 new panels, but also the 18 existing ones. Workarounds: Apparently one can add up to 1 kW or 10% of existing system size w/o triggering the switch. Any more than that would have to be in the form of a separate Zero-Export system, but that's going to be problematic, given that the concept is to generate production credits during summer and shoulder seasons.
  • Kaos
    Kaos Member Posts: 851
    Perfect is the enemy of good enough. The goal isn't to use zero grid but minimize it since it is expensive. With your costly power, even an oversized zero export setup where you waste some solar has a good ROI. With a bit of home automation, you can set the heat pump to run when you have extra PV and try to coast through peaks.
    You can also install an oversized resistance tank with a diversion controller to capture the excess PV. These are very common item overseas but are now some available here as well.
    Some car chargers also have the option to monitor load and can throttle back if the sun is not shining.
    PC7060
  • BTUser
    edited March 2025
    Agreed, zero grid isn't the objective. Objective is to minimize TCO. Point of the exercise here is to come up with the PV+A2AHP based option that does so, which would include some of the optimizations you're talking about.
    I'm assuming the resistance tank application would be limited to short term (a day, maybe a couple days) usage, so it could help some in the winter. Nevertheless, the NEM 3.0 issue appears to be a pretty significant consideration here. Apparently NEM 3.0 exports credits are only worth about 25% of import costs. Under utility agreements where import costs = export credits with annual true-ups, in effect with PV you have access to an unlimited amount of 100% efficient annual storage for your exports. That's huge and it's going to change what the optimization looks like.
    I suspect that gravy train is on its way out elsewhere too, at least in locations that continue to head toward electrification. As it does, it will lessen a key benefit that PV has had in the past, one that would play a non-trivial role in a PV+A2AHP+Forced Air vs Thermal+W2WHP+Radiant Hydronic comparison.
    hot_rod Member Posts: 27,073
    I'd like to see Resol offer these in the US and Canada.
    GGross
  • DCContrarian
    DCContrarian Member Posts: 1,431
    The next step would be to look at your gas bills and find the month with the highest therm usage. Then look up insolation for your location for that month, and average high temperature for your location for your month. Figure out what kind of thermal collector you would like to use, and calculate its efficiency at that outdoor temperature, and figure out how many panels you'll need to produce the heat equivalent of that number of therms, at that insolation and efficiency.
    That gives a lower limit on the size of a thermal system, you'd still need some sort of storage. But you can compare that to the PV size estimated above to get a ballpark of how competitive it will be.
    BTUser
  • jumper
    jumper Member Posts: 2,512
    Time POV. If your family is going to keep home for thirty years going off grid will eventually pay handsomely. That is because eventually anyone connected will have to pay her fair share of maintaining grid. No matter how few kwhr she requires. Similarly electric car owners will have to kick in road taxes.
    Larry Weingarten
  • Sol_Brother
    Sol_Brother Member Posts: 34
    I also have doubts about the efficacy of heating or cooling the dirt in a crawl space, but DC Contrarian, please educate yourself about drainback design before commenting about "elaborate schemes" for overheating and freeze protection. We in the business don't really consider gravity to be elaborate. Same for radiative cooling, also known as night sky radiant cooling. The low collector temperature limit is not that of local air temperature but the ability to radiate to the nighttime sky, which can produce fluid temps much lower than ambient air. Bristol Stickney of SolarLogic LLC did a lot of work with this type of system, and a quick search will reveal others' experiences.
    Unfortunately, as others have pointed out above, you really need a different collector (unglazed, open backed, and without selective surface coating) for this than what you want for absorbing heat.
    And Kaos, it is not all about Kool Aid versus science. There are other things to appreciate about solar thermal beyond debatable economics, like that it is a relatively approachable do-it-yourself project and, with the exception of the controller it involves simple, easy to understand and obtain parts. I have worked in PV as well as thermal and enjoy the ability to feel the result of my labors every time I take a shower or wash clothes, not just see it on my electricity bill, and my system has been heating most of my water since the Carter administration with absolutely minimal maintenance.
    Sol Brother
  • DCContrarian
    "The low collector temperature limit is not that of local air temperature but the ability to radiate to the nighttime sky, which can produce fluid temps much lower than ambient air."
    It's going to be the dewpoint of the air, once you hit dewpoint dew will start forming. Outdoors there is effectively an unlimited supply of humidity so you won't get below that. But you can get below ambient temperature for sure.
