Advice on a solution to leaking radiator; painting a previously painted cast iron radiator
I have an 1858 home in Maine with steam heat. I purchased the house in 1983 and I'm pretty sure most of the radiators are probably originals (other than one or two refurbished that were added during a kitchen renovation). A radiator in a small upstairs room started to leak from the bottom years ago and has been turned off, but I want to start using that room again. I contacted a company here in Maine that refurbishes radiators, thinking that mine was a goner and I'd need to replace it. I always thought this radiator was way too much for this little room and they agreed, after calculating btus based on the info I gave her. She recommended getting the sections apart and turning it into a 4-section radiator, instead of the current 10-section radiator. I would have to use wedges and a sledge hammer to get the sections apart and deliver them for the work. They no longer pick up and deliver. The quote was almost $700. $400 was for sandblasting and painting. So, I have contacted them to see if they'd still do the work WITHOUT the sandblasting and painting. To be honest, I had some radiators sand-blasted and painted 15 years ago. Some are showing rust and are pitted. A radiator I painted with a Rustoleum spray product about 13 years ago is holding up pretty well with some pitting at the section seams on top. Painting technology changes pretty quickly so I'm wondering what the current consensus is on painting one that is in pretty good shape paint-wise. Also, is the above solution the best one for me? Although I could probably order a radiator, I imagine shipping would be ridiculous. I have certainly disconnected and connected plenty of radiators in my 43 years in this house, in order to paint behind them, or to paint the radiators. But at age 71, I don't think I'm up to lugging a radiator up the stairs! The problem is, no one seems interested in doing radiator replacements A-Z around here. Splitting it into sections at least solves the issues of getting the monster down the stairs. The vendor estimated that each sections probably weighs 40 pounds, so that radiator is 400 pounds. If the resulting radiator was about 160 pounds, at least my kids could haul it up the stairs with a hand truck. Here are some photos. Thanks in advance. I've gotten good advice and help from you folks in the past and am a big Dan Holohan fan!
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,806
    edited February 25
    There are plenty for sale on CraigsList or Facebook Marketplace. Maybe you can find one matching the size you need locally or near buy.
    The one you have there is nothing special. And the cost to make it smaller is probably more than it's worth.
    They usually sell fairly cheaply. Unless you can do your own work, you'll have to find someone knowledgeable to handle and install it.
    If you'd like to keep the one you have, see if the "rebuilder of radiators" knows someone who will handle its delivery and installation. That's not a very big or heavy radiator as radiators go for someone familiar with these things.
    ethicalpaulrandom12345LynnLennox
  • Wcurtis
    Wcurtis Member Posts: 129
    I used this two years ago and so far it’s working flawlessly and brought new life to the old looking radiator.
    Make sure you tape off thoughtfully because its very runny and the spews go everywhere, doesnt mix like regular paint.
    Be prepared for a chemical smell after the radiator is used but it does slowly subside.
    Bought a radiator paint brush for the hard ro reach areas.
  • AdmiralYoda
    AdmiralYoda Member Posts: 737
    edited February 25
    Here is an alternative thought….maybe you and your kids can fix it yourselves?
    I had a similar radiator and one of the push nipples was rotted. I lied the radiator on its side and used four metal wedges, two on top and two on the bottom on each side of the push nipples and the sections came apart without too much trouble. I removed two sections and then reassembled. If too much heat is a concern you can always add a sloooooow vent or a TRV.
    Reassembly takes some effort. I had to put the radiator on its side against a solid surface (baseboard with a piece of scrap wood against it to prevent damage) and used a sledge hammer to mate the sections back together. They are a pretty tight fit and will take some pounding to go back….don't hammer the radiator directly, use a piece of scrap in between.
    Mine is still leak free about 7 years later. And the paint on your radiator doesn't look too bad. Clean it and put some fresh paint on it. No need for anything fancy. Some Benjamin Moore Ultra Spec HP primer and their Aura topcoat will make it look brand new!
    CLamb
    mattmia2 Member Posts: 15,453
    You can buy that style radiator new from us boiler or castrads. POR and KBS make some very durable direct to metal paints although they are likely overkill for that application.
    LynnLennox
    EdTheHeaterMan Member Posts: 11,547
    edited February 25
    One thing to consider is that all your other radiators may also be oversized.   If that is the case, you may want to rethink installing the correct size for that room.   It may not give you the balance you think you are going to get by installing the correct size.   That smaller radiator may need to operate for a longer cycle in order to get that room comfortable but all the oversized radiators will satisfy their respective rooms long before the proper size radiator gets even close to heating the room that it occupies    If it was grossly oversized and caused that room to overheat compared to the rest of the home, then a smaller radiator might be in order, but be careful as not to get a radiator that is too small.
    As for acquiring the replacement radiator, you may find that there are better deals available than shortening the one you have.   Wagner Salvage Has an eBay store and I have heard good things about them. I don't know how close you are to them but they can ship one radiator. Look at scrap and salvage yards near you for something that will fit your needs. Just make sure you can get full credit if the radiator is a leaker, otherwise don't buy it.
    mattmia2Long Beach Ed
    The new ones from US boiler seem pretty inexpensive too.
    Jamie Hall Member Posts: 26,798
    All good thoughts above — but, being me, I'll add a bit.
    Paint. I use a top quality acrylic paint, such as Benjamin Moore's Aura, and I've had exceellent results. Clean them thoroughly, use a hand wire brush to get as much rust off as you can, and paint happily. Any colour you want. And almost no smell…
    On taking a radiator apart. I do a good bit of car work, so I have no hand a pair of ball joint spreaders. NAPA, I think. They slip between sections, one at the top, one at the bottom, and use a screw to gradually spread. Quarter turn at a time, top and bottom in turns, and the radiator WILL come apart. Without damage (bashing on it may crack it). Then to put it back together, a smear of sealant on the nipples (very thing) or, if the nipples are shot, a ring of red RTV where the sections mate. Push it together by hand. Then use a pair of pipe clamps, again one at the top and one at the bottom. Again, quarter turn at a time, top and bottom by turns. Once it's all together, put in the tension rods, but just a bit over hand tight on the nuts. No more than that.
    mattmia2delcrossv
  • random12345
    random12345 Member Posts: 504
    edited February 26
    Speaking as a consumer and not in the trades, while the solutions presented above are useful and potentially doable for a 71 year old who's handy, that rad you have truly is nothing special as another poster said. Not worth preserving. I would buy a new rad with the same EDR and put a Maid O Mist vent with the smallest size opening (I think 4 is the smallest orifice size). Once you factor in paying a moving company to transport it to the radiator refinisher, getting it repainted, removing the bad section, you might as well just get a new one. A used rad is also a possibility, but again, you're going to need to pick it up and possibly repaint, and no guarantee it doesn't have problems. It's possible, even likely, that your boiler is oversized for the existing radiation, so I would not get a smaller rad which might throw off the balance of the whole system. That rad looks like it's about 32" tall, so it's probably 3.5 sq. ft./section, 35 sq. ft. EDR total. I found a site where you can get a slenderized 4 tube, 25" tall, 18 section rad (36 EDR) for a little over $700 including shipping to Bangor in 5-8 days. The rad is about $500, shipping is under $200. The point I'm making is that a new rad may not be as expensive as you think. I would not wait too long though because my understanding is most of these are made in China, and tariffs might have an impact.
    Long Beach Ed
  • LynnLennox
    LynnLennox Member Posts: 30
    edited February 27
    @random12345 Thanks for your input. When my kids were growing up, this little room was always someone's bedroom. It is the same size radiator that is in the other two, larger, bedrooms. I believe I measured it and it was either 32 or 36" tall with the legs. We always had to turn the steam off at night; otherwise it would be unbearable in there, even before the replacement windows and with 2 un-insulated walls. I would be getting this radiator out of the upstairs with the help of my kids, once it was apart in sections and I would be delivering it to the vendor. I'm in South Portland; the vendor is about 2 hours up the coast. Though it would fit in my trusty Civic's trunk; we'd probably pick up and deliver in one of my kids' pickup trucks. The vendor used to pickup and deliver, but finds it impractical now and they had to send someone to supervise so that no damage occurred to the homeowner's property. I asked them to take the sandblasting/painting off the quote and now it is under $300 for the work which would be replacing any worn nipples, making new tie rods, putting the radiator back together and testing. So it's starting to sound like this might be my best bet to getting heat back in that room. I am comfortable hooking it back up to the heating pipe since I've done that plenty of times. Thanks again.
    Stick a TRV on the vent so you can regulate the heat.
  • LynnLennox
    @AdmiralYoda I think my son has some wedges that might be suitable; he uses them to split wood. To be honest, my kids would gladly help with getting apart and out of my house and back in when reconfiugred, but they are so busy with jobs and my grandkids, I think I will leave the repair work to the professionals. The vendor did say that one or more nipples was probably the culprit. I got a new quote for under $300 with the sandblasting and painting removed. That was the majority of the quote. Interestingly, the vendor mentioned Benjamin Moore Aura in their quote, so I'll go that route since it sounds like they and you have had good results. It just needs some cleaning up to get the dust out and maybe some light "sanding" with a wire brush.
  • Long Beach Ed
    edited February 27
    Why not ask "the vendor" if he has a small one laying around for $100, which is the going price around here.
    If one nipple rusted out in yours, others may not be far behind.
  • LynnLennox
    @Jamie Hall Thanks Jamie. I'll go with the Aura paint. You are the 2nd person on this thread to mention it and the vendor was going to use it as well. I'm hoping I can get the radiator apart, laying it on its side and using wedges my son uses to split firewood. If not, I'll keep in mind the ball joint spreaders. Since the quote is now under $300 since removing the sandblasting and painting, I think I'll go that route; i.e get the radiator apart so it can be easily brought downstairs and into a vehicle and delivered to the vendor, who is about 2 hours up the coast from me. They can reduce it to 4 sections instead of two. They'd make new tie rods and replace nipples and put it back together and test it. It's hard to get anyone around here to address these kind of issues in steam-heated homes like mine, as far as plumbing/heating companies. So I think this may end up being the least labor-intensive and most cost effective solution for me. Once the kids get the radiator back up stairs, I'm comfortable with hooking it back up.
