Residential Steam Boiler Replacement - EDR Questions
Great catch. Very exciting! I thought for a second the 4 tube rad was a Republic Oriole, but it's not. Maybe the convectors though? We'll see.
I just finished reading "We got steam heat" by Dan Holohan. It's a great read and I was chuckling all the way through, but most importantly it gives a great description of steam systems, their components and how they work, all in simple terms (for guys like me:). I learned a lot from it.
Thanx for the suggestion, I would recommend it to anyone new to steam
2 -
Did you ever post pictures of the old boiler?
I posted a few in my original post, I can post better ones now
Front view:
Riser and Header:
Side view + Controls:
Main vent - front of building (it's a MoM #D):
Main vent - Rear (it's tucked in to a hole in the wall)
For the convectors, the stack height is important to determine the rating. It's measured from the floor of the enclosure to the top. See below. If you can't find any writing or identifying marks/symbols anywhere, then I would use the following to approximate:
Arco Convector No. 5, 28" L:
https://babel.hathitrust.org/cgi/pt?id=uiug.30112047386849&seq=26
You can also use the OCS sheet that was posted earlier. If the stack height is between the listed values just interpolate.
I dont have the stack height on hand, based on the following picture it looks like it is 17-18. This picture is measuring the outside of the enclosure from the floor
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
