White plume of smoke
joe143
Member Posts: 25
in Oil Heating
Hi - Just changed the oil pump on beckett burner and now everything it's on I'm getting a lot white smoke or steam from chimney. Had a very slow stream and it just stopped pumping so I replaced it.
White smoke from an oil burner usually means a fire that is way too lean….too much air in relation to the oil. Did you disturb the air adjustment while changing the pump?
Also the replacement pump may not be set to the correct oil pressure.
In either case you need a tech with a combustion test kit to adjust.
2 -
Too soon Ed!!
See my sight glass boiler videos: https://bit.ly/3sZW1el3
