Easy conversion from "Break on fall" vaporstats to "break on rise" ?
delcrossv
delcrossv Member Posts: 2,187
Seeing a number of the older mercury vaporstats on the 'bay that are "break on fall" with the contacts on the mercury tube on the left. Is there an easy way to make these break on rise? Maybe use the 'stat to power a relay coil?
Hopefully helpful pictures:
