Pipe over Filter thing
I don't know anything about HVAC. I bought a house in Nebraska and lived in it for about 9 years. I try to change the filter regularly but it's such a pain, i do neglect it. To remove the old filter, I rip it in half and yank it out. To install a new one I fold it in half, a bit, shove it past the pipe, unfold it and jam it into the grooves. I've had it serviced and was told whoever installed it was an idiot. I can't afford to fix it l. My roof has a tarp on it.
Am I doing it wrong. Every time i change the filter i come away with cuts on my hands and it's a horrible experience. Would the foldable filters i see on Facebook work? I hate this furnace. I'll add pictures.
    mattmia2 Member Posts: 16,745
    Whoever installed it didn't think about how to service it. Several ways you could fix it. I'd probably put a shorter nipple in the gas valve with a 45 on it, turn the tee on the gas riser 45 degrees, and put a longer nipple on one side of the union or the other. This is gas piping so whoever does it has to know what they are doing.
    pecmsg Member Posts: 7,053
    find the installer and beat the living hell out of him.
    that’s inexcusable.
    Find a contractor that will adapt a 4 inch meteor filter into that system.
    It pulls out the side
    mattmia2PC7060delcrossvEdTheHeaterMan
    fun fact, i got suspended from posting to facebook groups for a similar comment about painting wallpaper.
    you could also just change that filter housing to one that slides out the end instead of the top.
    PC7060delcrossv
  • delcrossv
    delcrossv Member Posts: 2,203
    I would have made the same comment. Bunch of weenies on FB- duly noted. 👍️
    it was the automatic flagging and that i said "shot", not someone reporting it.
    delcrossv
  • delcrossv
    Steamhead Member Posts: 18,493
    Based on some reactions I've seen, the same thing would have happened on NextDoor.
    Consulting
  • Jason23
    Jason23 Member Posts: 3
    Thanks for the info. Um l, I can't do the gas nipple thing. I haven't thought about a side access. I have a sawzall. Can I just cut down the side and make a side access door? I take full responsibility for my actions.
    EdTheHeaterMan Member Posts: 12,151
    edited February 2025
    YES. I have actually made a door hinge from duct tape and added a knob for opening the door. Duct tape folded over on the other side as a gasket
    I would cut the slot 1/3 to 1/2 the width of the filter box in the part where the filter is and get another piece of sheet metal and some sheet metal screws and screw a piece over the hole you cut. Could get some thumb turn buttons and screws and hold it on that way too.(actually I would move the gas pipe but my 2nd option would be to replace the filter box with a slot in the side.)
    Look at the manual for the furnace, is there a filter holder inside the furnace? Could you just remove the one from the duct and put the filter in the blower compartment?
  • Jason23
    The bottom is 1 whole part.
    not with snips it isn't
    delcrossvpecmsg
