Pipe over Filter thing
I don't know anything about HVAC. I bought a house in Nebraska and lived in it for about 9 years. I try to change the filter regularly but it's such a pain, i do neglect it. To remove the old filter, I rip it in half and yank it out. To install a new one I fold it in half, a bit, shove it past the pipe, unfold it and jam it into the grooves. I've had it serviced and was told whoever installed it was an idiot. I can't afford to fix it l. My roof has a tarp on it.
Am I doing it wrong. Every time i change the filter i come away with cuts on my hands and it's a horrible experience. Would the foldable filters i see on Facebook work? I hate this furnace. I'll add pictures.
Whoever installed it didn't think about how to service it. Several ways you could fix it. I'd probably put a shorter nipple in the gas valve with a 45 on it, turn the tee on the gas riser 45 degrees, and put a longer nipple on one side of the union or the other. This is gas piping so whoever does it has to know what they are doing.
I would have made the same comment. Bunch of weenies on FB- duly noted. 👍️
Aah. Coder weenies then. Gotcha.
Based on some reactions I've seen, the same thing would have happened on NextDoor.
Consulting0 -
YES. I have actually made a door hinge from duct tape and added a knob for opening the door. Duct tape folded over on the other side as a gasket
I would cut the slot 1/3 to 1/2 the width of the filter box in the part where the filter is and get another piece of sheet metal and some sheet metal screws and screw a piece over the hole you cut. Could get some thumb turn buttons and screws and hold it on that way too.(actually I would move the gas pipe but my 2nd option would be to replace the filter box with a slot in the side.)
Look at the manual for the furnace, is there a filter holder inside the furnace? Could you just remove the one from the duct and put the filter in the blower compartment?
The bottom is 1 whole part.
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
