Sizing baseboard heat for hot water boiler / /also sizing boiler
skibbereen_
skibbereen_ Member Posts: 2
edited February 11 in THE MAIN WALL
hi to all new here to the site. Can anybody give me direction on how to size hot water hydraulic baseboard, and size of boiler for a residential house?
  • skibbereen_
    typo hydronic.
    EdTheHeaterMan Member Posts: 10,858
    edited February 11
    First step is to know the Heat loss of the building. A professional that sells new heating equipment should be able to get that done for you. If this is a DIY job, then you will need to understand the basics of heat loss and get a room by room load calculation from someone that does this for a living. or try your luck on some of the less accurate online load calculators like https://builditsolar.com/References/Calculators/HeatLoss/HeatLoss.htm . These only do the whole house and will not offer you the amount of radiator needed for each room.
    …and we charge extra for Typos 🤣🤣🤣 because filling your radiators with hydraulic oil is messy and does not transfer heat as well as water does. 🤣🤣🤣
    Ironman
  • Ironman
    Ironman Member Posts: 7,740
    edited February 11
    There’s a fair amount of engineering in what you’re asking. As Ed mentioned, the first step is doing an accurate Manual J heat loss calculation. That’s the foundation for everything.
    From that, radiator sizing, boiler selection, piping strategy and sizing, pump and control selection are determined.
    There may still be a few supply houses that offer that service, but they’re getting few and far between. Most won’t work with or sell to homeowners.
    There may still be some on this site that will do it if you’re willing to pay for their services.
    Try re-posting with a heading like “Looking for Hydronic System Design Help”.
    Bob Boan
