Expansion tank thread size question
#90 expansion tank comes with 1/2" male threads. The equivalent floor standing model comes with 1" threads. Just wondering about the reason for the difference. Thanks
The ex-90 is 14 gallon, with 1/2" male threads. The sx-30v is also 14 gallon, but free standing, with 1" female threads. And good reason not to bush down the 1"? Is there any reason the free-standing would need larger pipe size?
A good question that I have often wondered about as well. I have often seen and installed with the lesser diameter size pipe bushed down or a reducing coupling used. Is it anything more than what @109A_5 says.
It might be that simple, but are there some type of load requirement besides system size?
Or tank design? The physics of the freestanding tanks seem to be the same as those mounted to the system piping. But that's just a guess
So…does anyone know the answer?
the Amtrol engineering book explains it well. It depends on the amount of expansion you need to accommodate, and the piping distances also. It is a free download that evert hydronics involved person should read
amtrol engineering handbook
Thanks. Will certainly take a look
@EBEBRATT-Ed said:
"In the Amtrol example they are talking about a system with 100 psi."
You forgot to mention the 7,000 gallons water volume and the 270 degree max average temperature. 😅
2 -
I remember a installing a wall hung boiler that was imported from Europe and rebranded by Hydrotherm. It was called the Celtic. The expansion tank was included within the cabinet and has a 1/4" OD copper line connecting the tank to the system.
So, "All expansion tanks are not connect equal" how unAmerican.
- 123 Chimneys & Flues
