Expansion tank thread size question
STEAM DOCTOR
STEAM DOCTOR Member Posts: 2,587
#90 expansion tank comes with 1/2" male threads. The equivalent floor standing model comes with 1" threads. Just wondering about the reason for the difference. Thanks
    109A_5 Member Posts: 3,960
    I would say it is the pipe size of the most common pipe size for the system application type.
    LRCCBJ
  • STEAM DOCTOR
    The ex-90 is 14 gallon, with 1/2" male threads. The sx-30v is also 14 gallon, but free standing, with 1" female threads. And good reason not to bush down the 1"? Is there any reason the free-standing would need larger pipe size?
  • Intplm.
    Intplm. Member Posts: 3,005
    A good question that I have often wondered about as well. I have often seen and installed with the lesser diameter size pipe bushed down or a reducing coupling used. Is it anything more than what @109A_5 says.
    It might be that simple, but are there some type of load requirement besides system size?
  • STEAM DOCTOR
    Or tank design? The physics of the freestanding tanks seem to be the same as those mounted to the system piping. But that's just a guess
  • psb75
    psb75 Member Posts: 1,126
    So…does anyone know the answer?
    hot_rod Member Posts: 27,414
    edited February 2025
    the Amtrol engineering book explains it well. It depends on the amount of expansion you need to accommodate, and the piping distances also. It is a free download that evert hydronics involved person should read
    amtrol engineering handbook
  • STEAM DOCTOR
    Thanks. Will certainly take a look
    EBEBRATT-Ed Member Posts: 20,150
    In the Amtrol example they are talking about a system with 100 psi.
    I don't think in a residential install the pipe size is critical.
    A little common sense and it will be fine
    Intplm.ethicalpaul
    EdTheHeaterMan Member Posts: 12,132
    Where can I send folks to take that course Ed? Common Sense 101
    I have heard that you can't fix stupid, but duct take can muffle the noise.
    jesmed1PeteAdelcrossvIntplm.
    mattmia2 Member Posts: 16,687
    perhaps the floor mount version is a well tank with a different label and fewer coating processes?
    1/2" is even bigger than needed for an expansion tank.
  • jesmed1
    jesmed1 Member Posts: 1,468
    @EBEBRATT-Ed said:
    "In the Amtrol example they are talking about a system with 100 psi."
    You forgot to mention the 7,000 gallons water volume and the 270 degree max average temperature. 😅
    PeteAEdTheHeaterMan
    I remember a installing a wall hung boiler that was imported from Europe and rebranded by Hydrotherm. It was called the Celtic. The expansion tank was included within the cabinet and has a 1/4" OD copper line connecting the tank to the system.
    So, "All expansion tanks are not connect equal" how unAmerican.
    As the boiler heats from a cold start expansion is gradual. It's not like the tank has to suddenly accept a ton of water.
    Anything 1/2" or larger would be fine.
    At least for residential
    mattmia2Intplm.
