Sludge in tank.
joe143
joe143 Member Posts: 25
Filter clogs when dow to 1/4 tank.Any suggestion on a additive to break it up
    ethicalpaul Member Posts: 8,780
    Maybe there's just not enough pressure (from the weight of the oil) at 1/4 tank
    pecmsg Member Posts: 7,053
    get the sludge pumped out.
    Intplm.
  • JDHW
    JDHW Member Posts: 107
    edited February 2025
    Are there companies that will "polish" the fuel? I used to be responsible for backup power generators that stored lots of fuel but used very little unless there was a power problem. After a few years the generators would not run for very long when required because to fuel filters blocked with bad fuel - bacterial growth. The solution was to get the maintence company to "polish" the fuel every year. Basically pump fuel from one end of the tank, through a filter and then back to the tank. A few hours of this each year solved the problem.
    Getting your current fuel "polished" could get you out of the hole. Anit-bacterial additives could be a long term solution if your fuel tank size and consumption is in reasonably balance. In the example quited above mine was not.
    HVACNUT Member Posts: 7,434
    Where is the tank? How old is the tank? Where does the oil line exit the tank? 1 pipe or 2 pipe? I don't believe sludge cares one bit what level the gauge says, unless it's soon after a delivery.
  • Intplm.
    Intplm. Member Posts: 3,013
    You can also try this.
    But what @pecmsg says here ^^^^^^^^ is your best option. Your oil company should have a truck that can pump you out.
