WiFi thermostat for steam system with programmable cycles
hello all, I am looking for a recommendation for a wifi thermostat that I can adjust the cycles on.
I have an old steam boiler (snowman) that is eating through oil because it cools down too much between cycles and uses a lot of oil to heat the water up again.
I know I need to eventually replace the whole system but I believe increasing frequency of cycles could help my case.
Thanks!
  • LRCCBJ
    LRCCBJ Member Posts: 1,043
    You can set the cycle time with a Tekmar 279. It's not wifi and it costs a fortune now.
    Dave in QCA
    EdTheHeaterMan Member Posts: 12,128
    edited February 2025
    You are not going to see much savings by adjusting the cycle time. A BTU is the amount of energy that it takes to raise one pound of water one degree. if you do that once an hour for 30 minutes, or you run the burner 20 times per hour for 1.5 minutes. You are going to see the same usage within 1 to 2 percent. The only way to get the oil usage to go down is to move the burner up to the place where the dead man that designed that boiler wanted the flame to be located.
    That way the oil burner will operate at 80% efficiency in stead of 50% efficiency. (meaning only 20% of the flame's heat will be lost up the chimney). Now you are letting over 50% of the heat from that oil burner's flame get lost up the chimney. I guess there are not many old timers that are interested in that job now a days.
    delcrossvethicalpaul
  • delcrossv
    delcrossv Member Posts: 2,203
  • Snowman1990
    Snowman1990 Member Posts: 23
    @EdTheHeaterMan or @delcrossv do either of you know anyone in the MA or RI area who could help me move that burner up? Thanks
  • delcrossv
    This is the link to my actual comment if @Charlie from wmass is interested at all. https://forum.heatinghelp.com/discussion/comment/1834880/#Comment_1834880
    finished product might look like this:
    Untitled Image
    delcrossv
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,425
    While what Ed said would save fuel. I am not the person to do that. With current prices of materials and labor it would be throwing good money after bad. If you are interested in a new boiler please contact me, we can discuss your options. Cycles is not going to save you much. Adding a vaporstat and improving venting will do more. The benefit is the vaporstat and venting can be used with the new boiler and won't be wasted funds.
    cell # 413-841-6726
    EdTheHeaterMandelcrossvHVACNUT
  • delcrossv
    @Snowman1990 ,DIY and just have someone setup the burner is still an option if replacement is not in the cards now.
