Electric water or Indirect water heater?
We have a small adu 720 sq, trying to choose between which water heaters to go with? We already have radiant flooring running off a gas boiler and could go with indirect water heater but the cost is triple.. We were considering Electric water heater because of the cost of the unit and efficiency. Would the monthly cost be cheaper if we did indirect? Please help, thank you!
  • bburd
    bburd Member Posts: 1,294
    The question of which is less costly to run depends on your utility rates, but in most places the indirect off a gas boiler will cost much less to operate than an electric resistance water heater; and a heat pump water heater may not be practical in an ADU due to the noise and the fact that there is usually no basement.
    However, the first cost of the indirect water heater will be higher as you have seen.
    ADUs generally don't use much hot water due to low occupancy.
    Bburd
    edwardpitzul
  • RascalOrnery
    RascalOrnery Member Posts: 137
    edited February 2025
    Anyone care to offer some comparison between lifetimes of hot water heaters vs indirects?
    edwardpitzul
    hot_rod Member Posts: 27,330
    7-10 years for a glass lined tank.
    Life expectancy comes down to how much water you run through the tank. How hard you water is, and the temperature.
    Is it a full time dwelling? One bath and kitchen? Wash machine?
    Jamie Hall Member Posts: 27,239
    They're both tanks. Given similar construction and maintenance, they will be similar. The "similar construction" is the kicker: very often electric water heaters are built to a price point, and thus may not be as robust. Lifetimes? Hard to say. 10 years for quality examples? 15 with good quality water? My direct oil fired ones — I have several — seem to last around 20 years.
    edwardpitzul
  • edwardpitzul
    edwardpitzul Member Posts: 28
    @hot_rod yes to all your questions.
  • edwardpitzul
    @hot_rod we are running on a well water.
  • edwardpitzul
    are both the heaters indirect and electric as well insulated inside and keep the water warm longer periods?
    electric tanks seem to last longer than gas fired, since there is no fire under the tank.
    It us tough to guesstimate dhw water usage, it varies widely from family to family Rarely do you hear someone complain about too much hot water
    All tanks now have good insulation to meet the energy standard, most are spray foamed no more thin fiberglass wraps
  • edwardpitzul
    @hot_rod thank you. Same insulation for indirect tanks?
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,067
    Hi, If you take time to do simple maintenance on a glass-lined tank, you can expect 40-50 years from it. It's just making sure the maintenance happens, along with controlling water chemistry somewhat and water pressure.
    Yours, Larry
    ethicalpaul Member Posts: 8,642
    I'd pick a heat pump water heater, second choice would be a resistive electric water heater (which I am quite sure will last a lot longer than 7-10 years), third choice would be an indirect which has so much installation cost and makes you keep running your boiler all year just to heat a few gallons of water per day, it's a solution that only a plumber could love.
    clammyGGrossKaosedwardpitzul
  • Kaos
    Kaos Member Posts: 858
    Typical ADU is space limited. Since you only have one bath, one of the smaller tankless (gas or electric) unit would also work and take up less space.
    Otherwise, a lowboy resistance tank with a big element hidden somewhere would be the next best option. Under stairs, above washer or in the corner cabinet if L shaped kitchen so it doesn't take up floor space.
    edwardpitzul
