Buderus gb142-24 boiler temp issue
I have a 13 year old Buderus gb142-24 boiler that needs service. I have the boiler temp set to 180, but the display shows the temp only going up to 144 degrees, will not go higher. I have tried to get it serviced but the techs do not seems to know the buderus system. Any recommendations on the temp issue.
Yes does have AM10 connected to boiler and I have the Thermostats set at 68 degrees and it is able to reach that temp
press the chimney button—-how hot does the boiler get? Try to find a heating person more familiar with the GB142
I think the Buderus Gb142 is a good boiler, esp. if it is installed well and "mates" with the building. I have one that I "adopted" and it has been going 17 yrs. now. I have kept the heat x-changer clean and replaced a fan and some venturi parts and of course ignition parts—all or which are still available. It hums along heating indirect DHW and large radiant slabs using outdoor reset.
Does the temperature climb for a domestic hot water demand?
Yes the temp climbs appropriately for DHW demand.
- 50 Industry Classes
