I'm picking up the torch on this one, although I see others have struggled with a similar issue without apparent resolution, for example:
After three failed attempts with Rectorseal and Blue Monster Tape, I am now seking a better alternative to sealing my Myson radiators located on the second floor of my new build. It sickens me to find these un-tapered threads so hard to seal. I spoke to the USA tech person at Myson and he suggested a few things, most which I have tried. Obviously, sealing parallel non tapered threads can be challenging.
I lasted 4 months since my last attempt before the dripping started after the radiators cooled from their last heating cycle. I have been looking into hydraulic BPT thread sealing devices (retained with a flange nut trapping the seal against the radiator and a sealing nut with o-ring (looks like one is available from China on eBay. I'm planning to start an evaluation once all pieces are in hand. I read this response from a previously closed post:
We now use a couple wraps of heavy teflon (be careful to keep it back from the end of the threads) and then a light smear of LeakLock sealant. We haven't had a leak in the last three years using these particular products and methods. I wouldn't worry about it.
I'm going to explore this LeakSeal product, but think my new approach of installing a sealing device may prove as a better solution. Any suggestions are welcome.
I have a number of Hudson Reed Radiators sold for the US market, along with their thermostatic valves. The valves are connected by a compression end onto a radiator tail that is threaded on the radiator side. The radiator tails bottom out and don't seal. The manufacturer has replaced the radiator several times under warranty, but their support never responds to my inquiry of how the radiators are threaded, bsp or npt. I attempted to connect two npt fittings, the shorter one clearly did not seal, the longer one did, kind of, but the connection seems imperfect. Sometimes it happens, but I have a feeling these are BSP female internal threads. From my research online, it appears that in places where BSP threading is used, it is very uncommon to produce a BSPT(tapered) female internal thread or coupling. Instead a BSPT(tapered) male fitting is paired with a BSP straight threaded female internal thread, which apparently will seal, while the reverse(straight male thread and tapered female) will not. In the US, npt female threads are common, and I'm unaware of whether an NPT male would seal with an NPS female. I'm considering trying to order a 15mm x BSPT radiator tail and hope it has a longer tapered thread than the one provided with the Hudson Reed valve. However I'd likely have to order from Europe, and it's hard to see how long the threads are. I'd love to hear any advice or ideas on how to get this to seal well. Thanks!
