Radiator for steam leaking water
Thoughts why it’s leaking? One pipe steam system
Do I need to pitch it? It wasn’t heating and I noticed the valve was leaking water when I turn it! I had replaced the valve.
Is there a simple way to raise up the baseboard radiator that I have? Do I get like a brick and put underneath? lol
yeah… but just under the end away from the inlet.
Have a man or other strong person do it or show you how to lift the end with the vent. While it is lifted, put something under that end that you don't need and that will hold the weight like a piece of wood or metal. Remove your hands to a place where they are safe. Your pockets are a good place. Tell your helper, if you are using one when your hands are clear and ask them to lower the baseboard slowly on the accouterment that you placed under it. Don't permit the brute to drop it or it may be damaged or damage something. The vented end (the end with the vent) should be at least an inch higher than the end connected to the pipe. Give it as much pitch as possible.
- 50 Industry Classes
