Any downside to high pitch?
delcrossv
delcrossv Member Posts: 2,189
I always see minimum pitch recited for mains and lateral runouts (1/4"/10 feet for parallel). I was wondering if there's any downside to significantly increasing pitch. Pipe erosion would be a guess, but is that ever seen in real life? With swing joints on everything there's no real limit. 2" in 10 feet would really get the condensate moving..
    Jamie Hall Member Posts: 27,007
    No, no downside (other than possible overhead clearance problems) but not much upside, either. The amount of condensate isn't that great.
  • ScottSecor
    ScottSecor Member Posts: 1,021
    Vertical steam mains and risers certainly have a lot of pitch.
    ethicalpauldelcrossvCLamb
  • delcrossv
    edited January 2025
    Spirax Sarco recommends 1:100 pitch so that's 1" every 8'4"- seems reasonable. Smaller water content boilers need quick condensate return.
