Viessman boiler and airflow plus not heating home
Jamie995
Jamie995 Member Posts: 13
Good day everybody we have a veissman vitodens 200 boiler system and a veissman airflow plus when we set the house temperature from the thermostat to 20° and the house is at 18°, it will cycle on and off multiple times and sometimes we'll stay on for an hour it will only heat the house maybe half a degree within those 2 hours this is very annoying because we live in a cold climate and have to light on our fireplace for most of the heat we've had a technician come out and take a look and replace a circulating pump and a few fuses and he said everything was good is there anything we could do to get more heat through the air exchanger as this is an expensive unit and it's really annoying to not be able to properly heat our home
«1
