UPS for electric heater
Need an uninterruptible power supply for 1500W to 2000W electric heater. We have frequent power outages that can last many hours and heater will not automatically restart when power is restored. Recommendations?
Thanks,
Gary
You might get a couple hours out of this. Keep in mind most of these batteries need to be replaced regularly as well. If the price doesn't scare you then call up a couple of these companies
how GREEN is that route?
If you look at the equipment the top one is a darker color, not green at all, the other one has just a little green on it. not enough to qualify for a subsidy I'm afraid :(
The start up delay of the Gen Set may still cause the lockout issue.
Does the heater have a remote start up capability that could be utilized to wake it up after a power outage restoration ?
Heater make / model ?
A UPS of that capacity is expensive and you may have to add additional batteries to extend the run time you want. And the batteries only last 3 - 4 years if they are the gel cell type. Maybe more cost effective to get another heater with the correct features, if an inexpensive remote start device can't be added.
One Pipe System1
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 963 Plumbing
- 385 Solar
- 15.3K Strictly Steam
