Options for flexible radiator plumbing?
Javelin
Javelin Member Posts: 158
Hi Heating Pros,
I'm redoing my bathroom and in the past have had a hard time reconnecting the old iron pipe supply/returns to the radiator… As I re-do this bathroom, I would like to add some insulation in the old radiator alcove which means that the rad won't fall on the original positions… SO, I'm wondering what you would all do.
Obviously I plan on draining the system and them I'm wondering if I can keep some sort of rigid copper/metal piping from the radiator nipples DOWN through the floor, but once in the joist bay, I'm wondering if I can/should switch to PEX which will give me more flexibility and make the rad re-install easier when the time comes?
Is PEX A ok to use? or would I need the oxygen barrier kind? if oxygen, does it work/cut/crimp the same way as A which I'm familiar with?
What have/would you all do?
THANK YOU!
Jay
PS - existing iron pipe is 1" OUTSIDE diameter.. so 3/4" pex maybe?
