Argo Elecdronic Block Boiler
Melannc
Member Posts: 1
Can anyone provide any information on this system? It is an Argo Elecdronic Block Boiler, I believe AI series, model 20.
Try getting in touch with Argo Controls (argocontrols.com). It's obsolete… what do you need to know about it?
Here is a I/O manual for a boiler that is newer than your boiler. ARGO AI B electric boiler. It may not be the exact same thing as your older boiler, but I think the information will be similar. I will keep looking for you boiler.
they are fairly simple under the hood, as far as troubleshooting. Are you having problems with it?
Wiring schematic is often inside the cover.
Living the hydronic dream0
