Argo Elecdronic Block Boiler
Can anyone provide any information on this system? It is an Argo Elecdronic Block Boiler, I believe AI series, model 20.
    Jamie Hall Member Posts: 27,644
    Try getting in touch with Argo Controls (argocontrols.com). It's obsolete… what do you need to know about it?
    EdTheHeaterMan Member Posts: 12,601
    edited January 2025
    Here is a I/O manual for a boiler that is newer than your boiler. ARGO AI B electric boiler. It may not be the exact same thing as your older boiler, but I think the information will be similar. I will keep looking for you boiler.
    hot_rod Member Posts: 28,009
    they are fairly simple under the hood, as far as troubleshooting. Are you having problems with it?
    Wiring schematic is often inside the cover.
