my NTI boiler only works during the day
My NTI boiler works during the day but not at night. The central heat function cycles through prepurge sometimes starts to run then goes back to prepurge. During the day it stays on heat until temps are reached. It switches to DHW pretty easily but only after the central heating temps are reached. My heating guy says it needs a new induction motor but if it's mechanical why would it only not work at night? Because it's not working at night it has to runn most of the day to warm the house. Any ideas?
    Jamie Hall Member Posts: 27,324
    Natural gas? Gas pressure drops at night in your area maybe?
    jesmed1PC7060
  • Ironman
    Ironman Member Posts: 7,903
    It’s a union boiler: it’s against its contract to work after hours.
    Bob Boan
    Tom_133PC7060Rich_49CLamb
  • Tom_133
    Tom_133 Member Posts: 970
    give us more info on what NTI boiler it is, and any other symptoms. Pics of the system as well if you can
    Tom
    Montpelier Vt
  • jesmed1
    jesmed1 Member Posts: 1,468
    edited January 2025
    If you're in Durango, CO, your night temps have been in the teens, and last night was down to single digits. @Jamie Hall may have the right idea. Are you on a ranch with a propane tank? If so you might have this problem:
