Gravity home heating
Message: i have a hydronic heating system in my house with the expansion tank location in the basement ceiling. have bleed all the rads. one side of house is ok. south side of house rads are cold tried to bleed them ( cold one) and just cold water coming out no air ? circulating pump has been changedthankssteve
    pecmsg Member Posts: 6,734
    gravity and a circulator?
  • jesmed1
    jesmed1 Member Posts: 1,260
    What is the water pressure in the system, and how many stories in the house?
  • JUGHNE
    JUGHNE Member Posts: 11,508
    Some pictures of boiler showing pump(s) and controls would help.
  • leonz
    leonz Member Posts: 1,731
    You have a steel compression tank in the ceiling joist.
    Turn the thermostat all the way up for a couple of hours to drive all the air out of the system.
  • delcrossv
    delcrossv Member Posts: 2,189
    edited January 10
    Tank been drained recently?
    Really would help to See what you have.
    hot_rod Member Posts: 26,428
    has the system been worked on recently, boiler pressure dropped off?
    What is the pressure at the boiler.
    Often times you need to purge a loop, venting the radiators will not move a bubble in the piping.
    Frozen pipes possibly?
