Smith 19A FA2003-59
I used 3/8 rope gasket on this 4 section smith 19, how do you know what you’re supposed to use the manufacturer doesn’t say in the paper work. I’ve used 1/2 before because I didn’t think it was right and my senior tech made me go back and change all it out.
Update for future reference: 3/8 rope per manufacturer on 19A series
Does it seal? if so… good to go.
That's a good point. This is too important to not know. Who supplied the boiler? Get a hold of them and make sure they send the corrcect rope gasket.
I used to keep a coil of 5/8 in the van. Sure it was maybe too big for some applications but it worked in so many places where the seals were gone. I hated seeing jobs where the gaskets were replaced with gobs of furnace cement. If it seals you're good. But of course you often have to do as the lead says. Unless of course it's dangerous of a violation.
2 -
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
