Help over filled boiler
anyone know how to reduce the water level in the sight glass i over flowed! I tried the red one above that white bucket but it’s still at the top!!!
that’s the right one, or I should say “a right one”. Keep draining
If you are above the gauge glass then it will be several gallons to drain. Maybe 5, maybe more.
Did water shoot out the radiator vents?
Steam systems are very forgiving, because they are so simple. It's just a pot of water with some pipes coming out of it after all 😃 Glad it worked out!
hi ethical Paul I was just looking at your videos!! Cool glass things on yours!!!
I would your take on my system as I am near you nj. One pipe system. Some hissing and clanging but no hammer. I want to move my some of bigger pipes in my basement but not sure if I can with the pitch and all. Also the whole system is is oddly placed, boiler in front, electrical back left, gas back right, so just a criss cross of piping and plumbing ect.1 -
feel free to contact me anytime via my link below. Clanging usually is hammer but different people call different sounds different things 😅
See my sight glass boiler videos: https://bit.ly/3sZW1el0
