Crane Boiler for water baseboard heat
I have a 1921 home with a Crane boiler system for water baseboard heat and it works perfectly. However I had it serviced last week and the young man from the local heat and air place used all my Bell & Gosset oil. I was told to just use a few drops in each reservoir a few times a year. Now I have a large spot of oil under my boiler motor. I am hopeful but worried that the excess amount of oil will damage the motor. Any thoughts. It’s wonderful heat and do not really wish to replace the unit.
    hot_rod Member Posts: 27,308
    a couple drops on both motor cups. That square cover you see with the oil cup has a cotton wick below that holds the remainder of the B&G oil tube. If it is saturated it will run out.
    techegirl71
    Jamie Hall Member Posts: 27,225
    If a little is good a lot must be better…. oh well. Probably won't hurt anything, though.
    EdTheHeaterMantechegirl71
    EdTheHeaterMan Member Posts: 12,022
    Over oiling is not a real problem but can cause a problem in the future.
    When you over oil the motor bearings, any excess oil will spill over and leak out of the oil cup and find its way on to the rubber motor mounts. over time that oil will cause the rubber to soften and cause the motor shaft and the pump shaft to move out of alignment. When that happens you will start to have coupling failure on a regular basis. If you find yourself in that situation you will need to replace both motor mount rings so the shafts line up properly. Part number 118223 from B&G or you can use this part number from Armstrong to get less expensive motor mount rings 810120-000
    bburdtechegirl71
  • techegirl71
    techegirl71 Member Posts: 3
    you are great. I appreciate your quick responses. I am going to relay all this info to he young man coming back tomorrow to look at what he’s done.
  • techegirl71
    I also found an owners manual pdf online from 1952 that I believe will be a good resource.
    just added a photo I forgot to add earlier.
    EBEBRATT-Ed Member Posts: 20,074
    Nothing in that picture is 1952 although the pump may be the same as the older pumps. The boiler looks like70s-80s
    techegirl71delcrossv
  • delcrossv
    delcrossv Member Posts: 2,200
    Agreed
