Crane Boiler for water baseboard heat
I have a 1921 home with a Crane boiler system for water baseboard heat and it works perfectly. However I had it serviced last week and the young man from the local heat and air place used all my Bell & Gosset oil. I was told to just use a few drops in each reservoir a few times a year. Now I have a large spot of oil under my boiler motor. I am hopeful but worried that the excess amount of oil will damage the motor. Any thoughts. It’s wonderful heat and do not really wish to replace the unit.
Over oiling is not a real problem but can cause a problem in the future.
When you over oil the motor bearings, any excess oil will spill over and leak out of the oil cup and find its way on to the rubber motor mounts. over time that oil will cause the rubber to soften and cause the motor shaft and the pump shaft to move out of alignment. When that happens you will start to have coupling failure on a regular basis. If you find yourself in that situation you will need to replace both motor mount rings so the shafts line up properly. Part number 118223 from B&G or you can use this part number from Armstrong to get less expensive motor mount rings 810120-000
2 -
you are great. I appreciate your quick responses. I am going to relay all this info to he young man coming back tomorrow to look at what he’s done.
I also found an owners manual pdf online from 1952 that I believe will be a good resource.
just added a photo I forgot to add earlier.
Agreed
Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
