"Duel fuel" Indirect
Other than HTP and Vaughn are there any reputable Manufactures that make an indirect water Htr that has a coil and electric elements?
ty.kcopp
You can use a regular electric tank heater and connect a plate HX plus a small recirc pump on an aqua stat for boiler heat. This is what I have and less money than anything indirect. Bonus, unlike a coil tank, you can easily clean the plate HX if you have hard water.
This is how some of the overseas tanks are built:
We had a dual fuel prototype tank that had a NG burner mid way up the tank, solar coil at the bottom. An interesting concept that fizzled with the last solar thermal wave.
Bock has a second company that rolls those large diameter coils that appear in other brands like BW, Laars, etc. They rolled a 30' long 1-1/2' tube into various coil diameters.
Then they were glass coated with the A.O. Smith Permaglas that you see on many old silos around the midwest.
The CombiCor 2 used that large steel coil also.
Living the hydronic dream1 -
- 50 Industry Classes
