"Duel fuel" Indirect
kcopp
kcopp Member Posts: 4,630
Other than HTP and Vaughn are there any reputable Manufactures that make an indirect water Htr that has a coil and electric elements?
ty.kcopp
    hot_rod Member Posts: 26,632
    I think Bock still offers them in both single and dual coil with element
    Bock manufactured the Caleffi solar tanks, they are a great heavy wall steel, glass lined tank
    kcopp
  • Kaos
    Kaos Member Posts: 848
    You can use a regular electric tank heater and connect a plate HX plus a small recirc pump on an aqua stat for boiler heat. This is what I have and less money than anything indirect. Bonus, unlike a coil tank, you can easily clean the plate HX if you have hard water.
    This is how some of the overseas tanks are built:
    kcopp
  • GroundUp
    GroundUp Member Posts: 2,467
    Just about any "solar" tank is set up this way. I had a customer recently that purchased a Richmond solar tank from the big box store and we tied his existing evacuated tube system into it, but any heat source could realistically perform the same task.
    kcopp
    We had a dual fuel prototype tank that had a NG burner mid way up the tank, solar coil at the bottom. An interesting concept that fizzled with the last solar thermal wave.
    Bock has a second company that rolls those large diameter coils that appear in other brands like BW, Laars, etc. They rolled a 30' long 1-1/2' tube into various coil diameters.
    Then they were glass coated with the A.O. Smith Permaglas that you see on many old silos around the midwest.
    The CombiCor 2 used that large steel coil also.
    kcopp
  • Ironman
    Ironman Member Posts: 7,871
    edited December 2024
    Bradford White still makes them, but I was just recently told there’s a five week lead time from RE Michel.
    Someone else may have one in stock somewhere.
    Bob Boan
    kcopp
