Better way to Install control wiring
Jalen_Jalen2006
Member Posts: 78
I’m no super tech, also on the less experienced side. Is there a way cleaner, more ORGANIZED way to run control wiring. I always see wiring this way and I’ve wanted to clean it up just don’t know what’s the best method or are there products specifically for this? this is horrible to troubleshoot and understand what’s going on.
I agree with @delcrossv
A terminal strip will clean things up a bit but your right low voltage is usually always a mess and the wiring being all different colors does not help.
It is usually a smaller part of a job and doesn't get the attention it deserves. Just like half **** condensate drains the no one pays attention to unless the ruin a ceiling
2 -
- 50 Industry Classes
