2-pipe Radiator Experiments, parts 1, 2, and now 3 with insane reverse pitch!!
2»
    109A_5 Member Posts: 4,157
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,430
    Because an appliance connector is often corrugated stainless steel tubing with a flare. Even though it's not actual csst. In the days of my youth they were corrugated brass tubing that were painted.
    cell # 413-841-6726
  • PC7060
    PC7060 Member Posts: 1,826
    Nice video series @ethicalpaul. Re you comments on why steam would come down the center versus the ends; I expect it’s because the end have more cooling/condensing capacity due to exposure to large volumes of cold air versus the center where the air gap between adjacent sections is small and being heated by each section.
    EBEBRATT-Ed Member Posts: 20,387
    I like @109A_5 drawing but with a couple mods
    I would put the drip in the bucket and submerge it in water as shown. Mark the bucket water level so you can figure out how much condensate your getting
  • delcrossv
    delcrossv Member Posts: 2,204
    Seems the only effect is the output is reduced due to the cold condensate in the corner.
    Looking forward to the one pipe tests. 😁
    ethicalpaul Member Posts: 8,922
    yeah sorry all. I called it that indeed because it is Corrugated Stainless Steel Tubing.
    I also used it with my evacuated tube solar hot water system and it was called that.
    after looking I see what I used here is FAC
    Thanks for the kind education!
  • PC7060
    edited January 2025
    @ethicalpaul - admire the work you put into your experiments!
    Are two pipe steam always configured high/low like your example? If not, reverse slope would impede steam inflow and presumably cause hammer noises.
    I think I have seen some that were low-low and yes that could be a concern then.
    Basically don’t do that 😅
    delcrossvPC7060
