Navien NCB 250-150
Hi everyone do I need recirculating pump on heating return line to drop pressure
I have 9 Radiators same time the pressure go up to 36 PSI
I Have 1 Taco 007-F5 On supply line
Thanks
Thank you this it’s my setup
Hi I notice when the boilers runs for heat if I open hot water faucet pressure go up to 36 PSI and safety valve it,s opening making noise
Thank you
Is that expansion tank piped to both the heating system and the DHW side but just valved off? what is the pressure on that expansion tank? it should say on the label somewhere the precharge, if someone changed it they would write it in sharpie or something. You also have a bunch of valves partially closed off for some reason?
Expansion tank it’s like 15 Psi from 40 PS
From tank it’s pipe to heating not to DHW
Those partials closed valve I did to reduce pressure in
Do I need to connect expansion tank to hot water supply to
Thanks
Thank you for all your help and suggestion this it’s what I did
Install Backflow and PRV
I Hope this will bring down the pressure
I did take out check valve and still the pressure go up to 36 PSI
I have to get Gordon Smith it’s licensed to contact NAVIEN
Thanks everyone
- 50 Industry Classes
