Navien NCB 250-150
marcelt66
marcelt66 Posts: 12
edited December 2024 in THE MAIN WALL
Hi everyone do I need recirculating pump on heating return line to drop pressure
I have 9 Radiators same time the pressure go up to 36 PSI
I Have 1 Taco 007-F5 On supply line
  • GGross
    GGross Posts: 2,119
    You need an expansion tank. Can you show a pic of the piping as installed?
    SuperTech
  • Thank you this it’s my setup
  • marcelt66
    marcelt66 Posts: 12
    Hi I notice when the boilers runs for heat if I open hot water faucet pressure go up to 36 PSI and safety valve it,s opening making noise
    Thank you
  • neilc
    neilc Posts: 3,214
    what year is the Navien? maybe heat exchanger is leaking thru(?)
    known to beat dead horses
    SuperTech
  • 2023
  • pedmec
    pedmec Posts: 1,491
    Your missing a PRV and Backflow
    GGross
  • GGross
    GGross Posts: 2,119
    Is that expansion tank piped to both the heating system and the DHW side but just valved off? what is the pressure on that expansion tank? it should say on the label somewhere the precharge, if someone changed it they would write it in sharpie or something. You also have a bunch of valves partially closed off for some reason?
  • Expansion tank it’s like 15 Psi from 40 PS
    From tank it’s pipe to heating not to DHW
    Those partials closed valve I did to reduce pressure in
    Do I need to connect expansion tank to hot water supply to
  • Thank you for all your help and suggestion this it’s what I did
    Install Backflow and PRV
    I Hope this will bring down the pressure
  • I did take out check valve and still the pressure go up to 36 PSI
    I have to get Gordon Smith it’s licensed to contact NAVIEN
    Thanks everyone
  • Hi everyone this it’s what I did so far so good
    Install a PRV on Auto Feeder Inlet (Make-up-Water) and so far issue that I use to have it’s gone
    Thank you everyone have a healthy and prosper new year
    GGross
