concentric vents
jjp76
Member Posts: 3
in Gas Heating
I have a gas furnace and a on demand tank less water heater both vented with concentric vents How far can the concentric be apart or how close one is lower on the roofline then the other but in line
Thanks!
says 4 inches to 24 inches between i see your point about one lower then the other so should i install across same elevation as the other would be my thought
-1 -
Yes.
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
