Steam Valve Sizing Question (heat distribution)
Quick question - I have Gorton #5s and #6s (or Maid-o-Mist equivalent) on my downstairs radiators, #5s on the second floor radiators and #D on the third floor radiators. Boiler is two flights below the downstairs.
The upstairs rooms, particularly those with the #Ds are a bit hot compared to downstairs. Would putting the Ds downstairs and the 5s and 6s upstairs help things? I'm trying to read and learn but its a bit hard to understand. Thank you!
No don't swap the D. The D is much too large for any radiator. Buy a 5 or 6 for upstairs. If the D is a Maid O Mist you can buy a #5 maid o mist and just swap out the orifice thing on top.
Thank you! i will do that. Just out of interest, would putting the D on one of the downstairs radiators warm up the downstairs a bit more? Or would i throw off the balance of the whole thing?
Try slowing the upstairs first.
I will repeat myself:
> No don't swap the D. The D is much too large for any radiator.NJ Steam Homeowner.
See my sight glass boiler videos: https://bit.ly/3sZW1el0
- 117 Geothermal
