Suggestions on removing a main vent
ohh. so then just one street 45 to come out of the original location. nipple and 90 facing me, another nipple, tee, first vent on the tee. street 90 and then the last vent?
Yes. You got it.
I like the first one better. As someone said earlier, you get the antler away from that other smaller return pipe by offsetting it that way
Street fittings are nice when tight for space, but do be aware that they are not as flexible as nipples into normal elbows…once they start to tighten up, they tighten up fast.
Definitely the first one. 👍️
Install so it's parallel to the main coming back at you from the concrete wall. You can lift the near end up some for additional pitch.
Very 1972. Reminds me of pizza hut.
hopefully the connections are tight enough and no leaks occur. eventually i want to replace the maid o mist with gortons since they’re preferred. but as long as i don’t get banging or hissing/noisy radiators im happy
thanks sharing for the pictures, looks like a great hang out room. The crown up in the ceiling looks to be early 1900s. When was your house built?
question for the pros: I’m not entirely familiar with steam, i changed the main vent because of radiator symptoms and water loss. Radiators are now quiet. However, the last vent that comes out of the 90s is a bit noisier then the first one. I’ve heard it whistle a couple times during the heat cycles. Kind of like a tea kettle Is this common? or a defective vent out of the box
pig tail is clean and easily to blow through. this is my pressuretrol setup
a pro would know more, however i asked AI and Chat GPT and according to them this is normal because the first vent is doing most of the venting and holds a bigger load. The second vent apparently has the ability to open and close more so the system can breathe. However i’m skeptical of them. I’m too old to trust Artificial intelligence
It also suggested that vents need to “break in”. Which i found odd, but maybe vents are like car engines and need to be broken in?
trol looks right,
maybe add another T and vent ?
known to beat dead horses0 -
it looks to me i’m out of room to add any more fittings.
i think i’ll order 2 gorton 1’s
yeah, that is why we don't use ai.
panting is not necessarily abnormal but the more pockets of water that are in the main the more it will happen. it is the steam advancing to a pocket of water and collapsing. do those vents have big holes on them, either a big orifice or no orifice?
big orfice but just barely threaded on, the plumbing store i got them from advised me to keep the orfices loose
will try, if anything i have gortons on the way, this is a temporary setup to at least have heat. hopefully the gorton design will keep them quiet. just concerned if the tight space will cause them to not fit
are the radiator vents all working?
one of the vents spits and gurgles. that’s on my to do list tomorrow. it’s one of the furthest radiators from the boiler, having a maid o mist C on it
C is most likely too fast. 5 maybe a 6.
there is no possible explanation for that bizarre advice
Probably didn't want you to crank it on there with a wrench such that it would be hard to remove.
Or they confused it with a hot water automatic air vent.
Hello…
Quick questions for those who know more then i do. After replacing those vents yesterday i’ve noticed the water in my sight glass slowly rise. I do not have an auto feed, i’ve checked it periodically when it’s cold and it stays the same, however after the boiler turns off and cools for an hour or 2. i’ve noticed about a half inch of water extra.
Before i was losing water everytime the boiler ran, now im gaining? Could someone kindly let me know what could be happening
There is nothing about those new vents that would affect your water level.
Do you mean it gains every time? Or it gains compared to where it is while it is steaming?
While it is steaming there is a quantity of steam and condensate out there in the system that takes some minutes to return to the boiler after the call for heat ends.
it gains everytime. For example the water level was higher this morning than it was last night. The water level is also higher now than it was when i checked it this morning.
So yes it’s gaining after it steams.
OK I'll reiterate it is unrelated to these vents. Some valve is leaking by, allowing water in. Water doesn't reproduce.
Check if your LWCO is adding water or if your manual feed is seeping. Also, if you have a turned off rad, it may be retaining condensate that dribbles back.
If you can, leave the system off for a few hours and see if the level is still rising.
No relation to the venting.
Last question for the pros, hopefully for a while. It has been suggested many times to add a low pressure gauge to the boiler to see what is actually happening. Would this be a good set up? thinking about inserting a tee and then 2 short nipples out the side with an elbow.
Only concern is if it will give false low readings
(i took the 30 off to see the readings, it has since been added back, but i definitely want to add the 0-3 )
You want the low pressure meter to be after the pigtail to protect it from steam
so would this work? it’s hard to see. there’s a short nipple that comes out of the boiler and goes to tee, the pigtail and pressuretrol thread on top of the tee. then a nipple to a second tee with nipples and elbow out the side?
- 86.3K THE MAIN WALL
- 53 Biomass
- 422 Carbon Monoxide Awareness
- 90 Chimneys & Flues
- 2K Domestic Hot Water
- 5.4K Gas Heating
- 99 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 3.3K Thermostats and Controls
- 53 Water Quality
- 41 Industry Classes
- 17 Recall Announcements
