Problems with gas valve??
ysh
ysh Member Posts: 3
Approximately once every 2 weeks my boiler flames making loud whining sound and flames appear larger than usual. Could it be gas valve putting out more gas than needed?
If not, what could be the issue?
Here is the picture of the noisy flame. You can see flame inside the tube.
And this is normal flame
    Jamie Hall Member Posts: 27,319
    More likely the regulator than the gas valve itself. You really need to have someone check the gas pressures coming into the house and before and after the regulator and at the gas valve to make sure they are correct.
  • JUGHNE
    JUGHNE Member Posts: 11,547
    You can see fire inside the burner tubes in the first pictures.
    Check pressure and clean burners, especially gas jets.
    Larry Weingartenmattmia2
    mattmia2 Member Posts: 16,672
    also make sure the burners aren't clogged with any debris like a spider web and aren't disintegrating. After cleaning the burners and checking the gas pressures, a combustion analysis would be a great idea.
    Also watch the burners when the blower comes on, they shouldn't change or move when that happens, if it does the hx is compromised.
    HVACNUT Member Posts: 7,424
    Huh, so that's what they call a fire tube boiler. Cool.
    delcrossv
    gas pressure is off.
  • ysh
    ysh Member Posts: 3
    are you saying there is not enough gas pressure? it happens really infrequently. is the gas valve a problem?
  • delcrossv
    delcrossv Member Posts: 2,203
    edited November 2024
    More likely the regulator. But check both.
    ysh
